====== BLM16x16+X V2 - Board ====== {{:phatline:BLM16x16-PCB-3D-Front.jpg?600|}}\\ {{:phatline:BLM16x16-PCB-3D-Back.jpg?600|}}\\ Since i need need a BLM16x16+X for my [[triggermatrix5]] And since Latigid ONs BLM is sold out [[mididocs:seq:blm16x16_build_guide]]... (and those 1N4148 Thruholes nightmare..) I made this new Version, based on Latigids Shematical Improvements. ====== Shematic ====== {{:phatline:BLM16x16-Shematic.pdf?400|}}\\ ====== Building and BOM====== The Values are printet on the PCB. {{:phatline:DAW-Encoder-Display-PCB.png?400|}}\\ **Following Quantity is for 1 PCB, Mouser:**\\ open following link: [[https://www.mouser.com/tools/part-list-import.aspx]]\\ **& copy past follwong list:**\\ 187-CL21B104KBFWPJE|7\\ 187-CL21A106KPFNNNE|4\\ 81-GRM219R60J476ME4D|4\\ 652-PEC11R-4015F-S24|9\\ 710-61201021621|3\\ 667-ERJ-P06F1001V|6\\ 660-RK73H2ATTD1002F|27\\ 660-RK73H2ATTD1002F|3\\ FIXME the 3x hc165 are missing\\ \\ You may change the how many times you want to order this project\\ aka you need it 10 times, then do this after importing the list into mouser...\\ if you need it 10 times it cost around 199€\\ \\ **6 Displays which you get from Ali:**\\ [[https://de.aliexpress.com/item/32638662748.html|SSD1306-128x64 7pin White]] ====== To Do ====== make a Frontpanel.\\ ====== Community users working on it ====== * **[[Phatline]]** = PCB & Shematic, UI-Programming, Documentation...\\ Just let a Private message on the forum to user already involved.\\ or join the forum: [[http://midibox.org/forums/topic/24791-daw-controller-ableton/|daw-controller-ableton]]\\
