* 4Midichannels @ each 512Steps X 32th-looprate X 128 CCs
* of course only a few of the 128CC should be used @ once - 4x128xCCs @ 32th is Midi Data MESS and µC Death
* maybe only 256Steps, will depend on RAM…. RealWorld will tell
* each TRACK has a shared Track length for all its 128 CCs
* Copy, Paste, Clear: for the all 128CCs/or single CC
* There is no EDIT, you can clear a CC or Track and make a new Take
Midibox:
Midi IN1 »> MelodySequencer and Remote Devices
Midi IN2 »> Midi Out from Synthesizer - which sends out the Moved CCs
Midi OUT »> Synthesizer input (Automated CCs merged with mididata from Midi IN1)
- a clear Acrylic Frontplate, with NO Engravings, UI-Labeling is viewable from PCB
Firmware not made yet
alot, beta test, programming the firmware, housing
will be interesting when using other synths then nord drum…
I have 10 ProtoBoards here - i test one, and if it works, i can share them for Beta Testing-if you pay the postage
