CV-1
CV-Recorder/Looper & CV-Generator
Control Voltage Recorder, Looper, and Generator - for a own Eurorack-Line… more in Future!
–this picture is the first prototype - pre-Eurorack
Features
* A Envelope which can be Recored from an AIN-Source, it can be Editet on Startpoint,ATK-Playbackrate, Decay-Playbackrate
* LFO which Waveform is stepless morphable from Sine Square Tri Saw-Up to Saw-Down…(only Clocksynced!)
* MSQ MotionSequencer to loop a CV-Signal.
* A Mixer Page which Mixes/Mutes ENV+LFO+MSQ - and scales the output CV
* Copy, Paste, Clear: to Transfair the CV Sequence to other CV1 Instances
Hardware Requirements
Midibox:
- dipcoref4 - this is the µC Brain for CV1
- no other PCBs needet - but expandable with other Eurorackmodules in Future
- µSD-Card, formated with FAT32
- Soldering Iron - with a Dip that can Handle SMD-Parts, Wires, solder Paste for the µC….
- Eurorack Power Source +-12V AND +5V!
Set
Cabeling
Midi IN1 »> CV1 Remote Device or a Midi-Sequencer
Midi OUT »> to a Global CV1 Remote Device - which will need a lot of Midiinputs M16?
- @JMidi1: connect your Sequencer to get Midiclock and Programchanges
- @JAIN1: 2 CV Inputs - 12V tollerant
- @JAUT3: 1 CV Output - (internal DAC with Protection Cirtuit > 12V Tollerant)
- @J19:Get up to 8 CV-Outputs, with a AoutNG
- @JLCD1: up to 4 Additional OLED-Displays for every one a Reset Line - so no additonal Circuit needet
- @J89: DIN and DOUT Shiftregister Chain: thought for decidet Expander Modules (which will come in near future
- @J2/Bootload: If the core is not starting up - because of bad-Firmware, then bridge this Jumper to come into the Bootload-Mode
Software
Firmware
yes it loopin… but not good enough to release anything…
Building
Frontpanel
- Eurorack Alu-Plate
Case
BOM
Comment | Designator | Footprint | LCSC Part Number | Library Type | |
100nF | C1,C2,C3,C4,C5,C6,C7,C8,C9,C10 | midibox:1206-C | C24497 | basic | |
10uF | C11,C12,C13,C14,C15,C16,C23,C24,C25 | midibox:1206-C | C13585 | basic | |
10pF | C17,C18,C19,C20,C21,C22 | midibox:1206-C | not avaiable | ||
1N4148W | D1,D2,D3,D4,D5,D64 | midibox:SOD123-DIODE | C81598 | basic | |
ENC | ENC1,ENC2,ENC3,ENC4,ENC5 | midibox:ENC-PEC11R | 652-PEC11R-4015F-S24 | ||
5×2-AOUT | J19 | midibox:Header-2×5 | |||
BootLoad | J2 | midibox:Header-1×2 | |||
DinDout | J89 | midibox:Header-2×5 | |||
HEADER_3 | JAIN1 | midibox:Header-1×3 | |||
Header-1×4 | JAIN2 | midibox:Header-1×4-female | |||
Header-1×4 | JAIN3 | midibox:Header-1×4 | |||
CV1 | JAUT1,JAUT2 | midibox:Header-1×2 | |||
CV-OUT1 | JAUT3 | midibox:Header-1×2 | |||
BiOff | JG1 | midibox:Header-1×2 | |||
Gain | JG2,JG3 | midibox:Header-1×2 | |||
Disconnect | JG4 | midibox:Header-1×2 | |||
Offset | JG5 | midibox:Header-1×2 | |||
Foot | JG6 | midibox:Header-1×2 | |||
Gates | JGate1 | midibox:Header-2×3 | |||
OLED3-6 | JLCD1 | midibox:Header-2×7 | |||
Midi | JMidi1 | midibox:Header-2×3 | |||
Header-2×8-eurorack | Jpsu1 | midibox:Header-2×8-only-nose | |||
DIPCOREF4_52P | M1 | dipcore-V2C:dipCoreF4_v2c-52p-DIP-40-CMPNT_CORE_52P | |||
uSD_DM3ATDM3AT | M2 | midibox:uSD-DM3AT-SF-PEJM5 | 798-DM3AT-SF-PEJM5 | ||
6N138 | M3 | midibox:DIP-8 | 512-6N138M | ||
LED-Green | Menue-1,TR1,Clock-1,ENV-1,Menue-2,TR2,ENV-2,Menue-3,Menue-4,Menue-5,Menue-6 | midibox:1206-LED | C559120 | extended | |
OLED | OLED1,OLED2 | SSD1306:OLED-SSD1306-128×64 | |||
PTC | PTC1 | midibox:1206-R | C126818 | extended | |
10K | R28,R29,R43,R44,R45,R46,R47,R48,R49,R50,R51,R52,R53,R54,R55,R56,R57,R58 | midibox:1206-R | C17902 | basic | |
49K9 | R30,R31,R32,R33,R34,R35,R36,R37,R38,R39,R40,R61,R62,R64 | midibox:1206-R | C18017 | extended | |
30K | R41,R42 | midibox:1206-R | C17999 | extended | |
130K | R59 | midibox:1206-R | C17893 | extended | |
100K | R60 | midibox:1206-R | C17900 | basic | |
1K | R1,R2,R3,R4,R5,R6,R7 | midibox:1206-R | C4410 | basic | |
4K7 | R8 | midibox:1206-R | C17936 | basic | |
220 | R9,R10,R11,R12,R13,R14,R15,R16,R17,R18,R19,R20,R21,R22,R23,R24,R25,R26,R27,R63 | midibox:1206-R | C17958 | basic | |
Trim-3224W-1-104E | RV1,RV2 | midibox:Trimmer-3224W-1 | C53229 | extended | |
Trim-3214W-1-253E | RV3 | midibox:Trimmer-3214W_Vertical | 652-3214W-1-253E | ||
74HC595 | S1,S2,S3 | midibox:SOP-16_SOIC-16 | C5947 | basic | |
74HC165 | S4,S5 | midibox:SOP-16_SOIC-16 | C5613 | basic | |
TL072 | U2,U3 | midibox:SOP-8_SOIC-8 | C6961 | basic | |
MCP6002 | U6 | midibox:SOP-8_SOIC-8 | C7377 | basic | |
mouse-cut | cut1,cut2,cut3 | midibox:mouse-cut |
To Do
a housing/case or frontplate
Resources
Community users working on it
I have ProtoBoards here - i test one, and if it works, i can share them for Beta Testing-if you pay the postage
