dipBoardF4
MIDIbox Hardware Platform extension for dipCoreF4.
Features
Very small size 65x46mm(less than your credit card).
Very low profile.
Your application board can be stacked on bottom with 'Micro-match' connectors.
The
dipCoreF4 can be installed on the two side.
Provides all the most important features and ports as a regular mbhp.
Compatible with Andy's
USB and
RES-SD modules.
Dimension
PCB
2 layers PCB design.
Fits 2 layer mostly common design rules.
min. drill 10mil
min. width 6mil
Top copper
Bottom
Ports and features.
Compatible/stack-able boards options
M16 Interface, stack-able, to connect on a SPI port, provides 16 MIDI IO and 48 GPIO
toDo
