MIDIbox Hardware Platform extension for dipCoreF4.
version 1. Mouser BOM:toDo
Qty | Value | Package | Parts | Mouser | Reichelt | Conrad | Other | Notes |
Resistors | ||||||||
2 | 680R 5% | 0603 | R1, R2 | Depends on Leds | ||||
4 | 1K 5% | 0603 | R3, R4, R5, R6 | R3 if you use CAN without transceiver | ||||
PTC fuses, resettable thermistors | ||||||||
1 | 1206L150THWR | 1206 | L1 | 576-1206L150THWR | ||||
Capacitors | ||||||||
1 | 100n | 0603 | C2 | |||||
1 | 47u | SMC_B | C1 | |||||
Diode | ||||||||
1 | 1N4148WS | SOD323-W | D1 | 512-1N4148WS | Only if you use CAN without transceiver | |||
LEDs | ||||||||
2 | – | 0805 | 5V, 3V3 | |||||
dipCoreF4 socket | ||||||||
2 | 1×20 | low profile female | 517-929870-01-20-RA | for pads 1 to 40 | ||||
2 | 1×5 | low profile female | 517-929870-01-05-RA | for pads 41 to 50 | ||||
1 | 1×2 | low profile female | 517-929870-01-02-RA | for pads 51 to 52 | ||||
Connector | ||||||||
1 | micro-match 2×6 | Female | J1A | 571-8-215079-2 or 571-1-2178710-2 (value line) | Place on top | |||
3 options available for PORTs connectors(depends on you app.) | ||||||||
Option 1 - Regular Shrouded Headers | ||||||||
3 | 2×3 | Male | J5, J11, J18 | 710-61200621621 | Place on top | |||
4 | 2×5 | Male | J4, J8/9, J15, J19 | 710-61201021621 | Place on top | |||
1 | 2×7 | Male | J16E | 710-61201421621 | Place on top | |||
Option 2 - Stacking Micro-Match Connector | ||||||||
1 | 2×2 | Female | J1B | 571-7-215079-4 or 571-2178710-4 (value line) | Place on bottom | |||
3 | 2×3 | Female | J5, J11, J18 | 571-215079-6 or 571-2178710-6 (value line) | Place on bottom | |||
4 | 2×5 | Female | J4, J8/9, J15, J19 | 571-12150790 or 571-1-2178710-0(value line) | Place on bottom | |||
1 | 2×7 | Female | J16E | 571-8-215079-4 or 571-1-2178710-4 (value line) | Place on bottom | |||
Option 3 - Micro-Match Paddle Board for low profile connector | ||||||||
3 | 2×3 | IDC | J5, J11, J18 | 571-7-215570-6 | Place on top | |||
4 | 2×5 | IDC | J4, J8/9, J15, J19 | 571-8-215570-0 | Place on top | |||
1 | 2×7 | IDC | J16E | 571-8-215570-4 | Place on top |
toDo
toDo
