====== dipBoardF4 ====== MIDIbox Hardware Platform extension for [[dipcoref4|dipCoreF4]]. ==== Features ==== * Very small size 65x46mm(less than your credit card). * Very low profile. * Your application board can be stacked on bottom with 'Micro-match' connectors. * The [[dipcoref4|dipCoreF4]] can be installed on the two side. * Provides all the most important features and ports for regular mbhp. \\ ==== Dimension ==== {{ :antichambre:1808_dipboard_v1.beta_docu_dim.png?600 |}} \\ ===== PCB ===== <WRAP group> <WRAP column 60%> {{ :antichambre:1809_dipBoardF4_v1.beta_top.png?500 |}} \\ {{ :antichambre:1809_dipBoardF4_v1.beta_bottom.png?500 |}} </WRAP> <WRAP column 35%> 2 layers PCB design.\\ Fits 2 layer mostly common design rules. * min. drill 10mil * min. width 6mil </WRAP>\\ </WRAP>\\ <WRAP column 60%> Top copper {{ :antichambre:1809_dipBoardF4_v1.beta_layer_top.png?500 |}} \\ Bottom {{ :antichambre:1809_dipBoardF4_v1.beta_layer_bottom.png?500 |}} </WRAP> \\ ===== BOM ===== version 1. Mouser BOM:<wrap round todo 7%>toDo</wrap> ^Qty ^Value ^Package ^Parts ^Mouser^Reichelt^Conrad^Other^Notes^ ^Resistors^^^^^^^^^ |2 |680R 5% |0603 |R1, R2 |[[https://www.mouser.fr/ProductDetail/Panasonic/ERJ-PA3J681V?qs=sGAEpiMZZMvdGkrng054t6%2fAfIpq60YDGGtXI%252bjCSgEeBlnz3sOAbg%3d%3d| 667-ERJ-PA3J681V ]] | | | |Depends on Leds | |4 |1K 5% |0603 |R3, R4, R5, R6 |[[https://www.mouser.fr/ProductDetail/ROHM-Semiconductor/ESR03EZPJ102?qs=%2fha2pyFadujPfy170iHVGEtMFtzogPGwOHcYAAOLl%2f9T6PIvTHXpgQ%3d%3d|755-ESR03EZPJ102 ]] | | | |R3 if you use CAN without transceiver| ^PTC fuses, resettable thermistors^^^^^^^^^ |1 |1206L150THWR|1206|F1|[[https://www.mouser.fr/ProductDetail/Littelfuse/1206L150THWR?qs=%2fha2pyFaduhlexFGoLte04X2tL%252bbW3Ma%252b9epP3LU68QBDZh6rRT18Q%3d%3d|576-1206L150THWR]] | | | | | ^Capacitors^^^^^^^^^ |1 |100n |0603|C2 |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/885012206071?qs=sGAEpiMZZMs0AnBnWHyRQEGbLOF2VP1iprT3n4FXsKyn%252b5OoMJVgRQ%3d%3d|710-885012206071 ]] | | | | | |1 |47u |SMC_B|C1 |[[https://www.mouser.fr/ProductDetail/AVX/F931C476MBA?qs=sGAEpiMZZMuEN2agSAc2pqQ%252bITMkn5QQ6gzliyJ0Sb1gSCIIsQXxrg%3d%3d| 581-F931C476MBA ]] | | | | | ^Diode^^^^^^^^^ |1 |1N4148WS|SOD323-W|D1 |[[https://www.mouser.fr/ProductDetail/ON-Semiconductor-Fairchild/1N4148WS?qs=sGAEpiMZZMtoHjESLttvkr4bXZrJfFziTdC5C0Y1oek%3d|512-1N4148WS ]] | | | |Only if you use CAN without transceiver | ^LEDs^^^^^^^^^ |2 |--|0805 |5V, 3V3 |[[https://www.mouser.fr/ProductDetail/755-SML-H12U8TT86C|755-SML-H12U8TT86C]] | | | | | ^dipCoreF4 socket^^^^^^^^^ |2 |1x20 |low profile female| |[[https://www.mouser.fr/ProductDetail/517-929870-01-20-RA| 517-929870-01-20-RA]] | | | |for pads 1 to 40| |2 |1x5 |low profile female| |[[https://www.mouser.fr/ProductDetail/3M-Electronic-Solutions-Division/929870-01-05-RA?qs=sGAEpiMZZMs%252bGHln7q6pm%252bCiuHjnbsudfRsikv%252bK%252bu4%3d|517-929870-01-05-RA ]] | | | |for pads 41 to 50| |1 |1x2 |low profile female| |[[https://www.mouser.fr/ProductDetail/3M-Electronic-Solutions-Division/929870-01-02-RA?qs=sGAEpiMZZMs%252bGHln7q6pm%252bCiuHjnbsudnrpQb%2fhOxhg%3d|517-929870-01-02-RA ]] | | | |for pads 51 to 52| ^Connector^^^^^^^^^ |1 |micro-match 2x6 |Female|J1A |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215079-2?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg1R8%252bHzdf0ck%3d|571-8-215079-2]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/1-2178710-2?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8Bh9SlB9BUSeJ3BKKERN%252bmg%3d%3d|571-1-2178710-2 (value line)]] | | | |Place on top | ^3 options available for PORTs connectors(depends on you app.) ^^^^^^^^^ ^Option 1 - Regular Shrouded Headers^^^^^^^^^ |3 |2x3 |Male |J5, J11, J18 |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61200621621?qs=sGAEpiMZZMs%252bGHln7q6pm%2fFhW%252btWvhAgbNxkR%252blwXp8Ip%2fAN9J9VOg%3d%3d|710-61200621621 ]] | | | |Place on top | |4 |2x5 |Male |J4, J8/9, J15, J19 |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61201021621?qs=sGAEpiMZZMs%252bGHln7q6pm%252bxnWLfLL2%2f93mYWvuMVZAY%3d|710-61201021621 ]] | | | |Place on top | |1 |2x7 |Male |J16E |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61201421621?qs=sGAEpiMZZMs%252bGHln7q6pm%2fFhW%252btWvhAggwcPHCC2CMNxOm0Mua7X2Q%3d%3d|710-61201421621 ]] | | | |Place on top | ^Option 2 - Stacking Micro-Match Connector^^^^^^^^^ |1 |2x2 |Female |J1B |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/7-215079-4?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgAB%252bkBgSN8jE%3d|571-7-215079-4]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/2178710-4?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8xlKrGrnZbKU8jgpyiX7BKg%3d%3d|571-2178710-4 (value line)]] | | | |Place on bottom | |3 |2x3 |Female |J5, J11, J18 |[[https://www.mouser.fr/ProductDetail/TE-Connectivity/215079-6?qs=sGAEpiMZZMs%252bGHln7q6pm48SVpWlpfsECZqIi2rkWjs%3d|571-215079-6]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/2178710-6?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8lDoKaCIVjpqtoiZwdtC2Ng%3d%3d|571-2178710-6 (value line)]] | | | |Place on bottom | |4 |2x5 |Female |J4, J8/9, J15, J19 |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/1-215079-0?qs=sGAEpiMZZMs%252bGHln7q6pm48SVpWlpfsEzrkPwTkOYWM%3d|571-12150790]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/1-2178710-0?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8toxxH7bCeDjvZhYFCVsCFg%3d%3d|571-1-2178710-0(value line)]] | | | |Place on bottom | |1 |2x7 |Female |J16E |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215079-4?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgiXa3C2mAfII%3d|571-8-215079-4 ]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/1-2178710-4?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz89XsOpPMY05YgpC5omewCbA%3d%3d|571-1-2178710-4 (value line)]] | | | |Place on bottom | ^Option 3 - Micro-Match Paddle Board for low profile connector^^^^^^^^^ |3 |2x3 |IDC|J5, J11, J18 |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/7-215570-6?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgk4IYNQOS%252bLA%3d|571-7-215570-6 ]] | | | |Place on top| |4 |2x5 |IDC|J4, J8/9, J15, J19 |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215570-0?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg0iDJ6yhwCXo%3d|571-8-215570-0 ]] | | | |Place on top| |1 |2x7 |IDC|J16E |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215570-4?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg2wTWzyi6GTY%3d| 571-8-215570-4 ]] | | | |Place on top| ---- ===== Ports and features. ===== <wrap todo>toDo</wrap> \\ ---- ===== Compatible/stack-able boards options ===== * All [[http://ucapps.de/|uCapps]] mbhp modules are compatibles. * [[dipboardf4_modules|USB, SD-Card, External Power and MCAN modules]] are available. * [[m16|M16 Interface]], stack-able, to connect on a SPI port, provides 16 MIDI IO and 48 GPIO 8-) \\ \\ For any questions, informations or observations do not hesitate to contact me (Forum).\\ [[antichambre|Antichambre.]]\\
