====== dipBoardF4 Modules====== Basic connection Modules for [[dipboardf4|dipBoardF4]] and [[dipcoref4|dipCoreF4]]. ==== Features==== * Dual OTG USB, one Dual role(mini-AB, A) and second is Host only(B). * DC Input 9-12V with 5V regulator, switch and led. * In device Mode, VBUS is switched off when DC Input is enough to supply the 5V regulator. * Power switch also acts on USB powering. * micro-SD Card socket with push-push. * Reset and User buttons, 2 leds for user purpose. * Dual MCAN bus RJ11 connectors with 120Ω termination switch. \\ ==== Dimension ==== {{ :antichambre:1809_dipcoref4_v1.modules.beta_dim.png?600 |}} \\ ===== PCB ===== <WRAP group> <WRAP column 60%> {{ :antichambre:1809_dipcoref4_v1.modules.beta_top.png?500 |}} \\ {{ :antichambre:1809_dipcoref4_v1.modules.beta_bottom.png?500 |}} </WRAP> <WRAP column 35%> 2 layers PCB design.\\ Fits 2 layer mostly common design rules. * min. drill 10mil * min. width 6mil </WRAP>\\ </WRAP>\\ ===== BOMs ===== ==== USB Module ==== version 1. Mouser BOM:<wrap round todo 7%>toDo</wrap> ^Qty ^Value ^Package ^Parts ^Mouser^Reichelt^Conrad^Other^Notes^ ^Resistors^^^^^^^^^ |4 |22R 5% |0603 |R1, R2, R3, R4 | | | | | | |1 |680R 5% |0603 |R5 | | | | |Depends on Led | ^PTC fuses, resettable thermistors^^^^^^^^^ |1 |1206L150THWR|1206|F1|[[https://www.mouser.fr/ProductDetail/Littelfuse/1206L150THWR?qs=%2fha2pyFaduhlexFGoLte04X2tL%252bbW3Ma%252b9epP3LU68QBDZh6rRT18Q%3d%3d|576-1206L150THWR]] | | | | | ^Capacitors^^^^^^^^^ |1 |100n |0603|C2 | | | | | | |1 |4,7u |SMC_A|C1 | | | | | | ^ESD Suppressors / TVS Diodes ^^^^^^^^^ |7 |CG0603MLC-05E|0603|Z1, Z2, Z3, Z4, Z5, Z6, Z7|[[https://www.mouser.fr/ProductDetail/Bourns/CG0603MLC-05E?qs=%2fha2pyFaduj8GWc5RpRwWsoz%252bsBNDfM0b%2fMwO0m8cAS%252b28tb9AwLWQ%3d%3d|652-CG0603MLC-05E ]] | | | | | ^Ferrite Bead^^^^^^^^^ |1 |BLM21|0805|L1 |[[https://www.mouser.fr/ProductDetail/Murata-Electronics/BLM21PG221SN1D?qs=sGAEpiMZZMtdyQheitOmRdaiwhWWI9YttJulw31NHCk%3d|512-1N4148WS ]] | | | | | ^LEDs^^^^^^^^^ |1 |--|0805 or THT |LED_OC | | | | |2x5mm rectangular THT | ^Transistor^^^^^^^^^ |1 |FDN304P |SSOT-3 |Q1 |[[https://www.mouser.fr/ProductDetail/ON-Semiconductor-Fairchild/FDN304P?qs=sGAEpiMZZMshyDBzk1%2fWi6u8DDnmpUwtybEcsh7Clog%3d|512-FDN304P ]] | | | |P-Channel MOSFET| ^IC^^^^^^^^^ |1 |STMPS2161STR|SOT23-5L|IC1 |[[https://www.mouser.fr/ProductDetail/STMicroelectronics/STMPS2161STR?qs=%2fha2pyFaduiAy%2fdT8k4k1fxaG8i6c%252bD3RLmjnwWa517tnLVTGOOraA%3d%3d|511-STMPS2161STR ]] | | | |Power Switch IC | ^Connectors^^^^^^^^^ |1 |mini-USB |THT |MINI-USB |[[https://www.mouser.fr/ProductDetail/TE-Connectivity/1734510-1?qs=sGAEpiMZZMulM8LPOQ%252byk5iMqoToDEs%2fWOccw2Kf2Ys%3d|571-1734510-1]] | | | | | |1 |USB-B |THT |USB-B |[[https://www.mouser.fr/ProductDetail/538-67068-8000|538-67068-8000 ]] | | | | | |1 |USB-A |THT |MINI-A |[[https://www.mouser.fr/ProductDetail/538-48204-0001|538-48204-0001]] | | | | | |1 |micro-match 2x4 |Female|J2A |[[https://www.mouser.fr/ProductDetail/TE-Connectivity/7-215079-8?qs=sGAEpiMZZMs%252bGHln7q6pm48SVpWlpfsEUiVE5fgbiD4%3d|571-7-215079-8 ]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/2178710-8?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8%2fCQlcYGYnC2hwh1bE9lC1w%3d%3d|571-2178710-8 (value line)]] | | | | | |1 |micro-match 2x6 |Female|J1A |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215079-2?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg1R8%252bHzdf0ck%3d|571-8-215079-2]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/1-2178710-2?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8Bh9SlB9BUSeJ3BKKERN%252bmg%3d%3d|571-1-2178710-2 (value line)]] | | | || ^Others ^^^^^^^^^ |2 |Screw terminal |-- |-- |[[https://www.mouser.fr/ProductDetail/534-7790|534-7790 ]] | | | | | \\ ==== External Power Module ==== version 1. Mouser BOM:<wrap round todo 7%>toDo</wrap> ^Qty ^Value ^Package ^Parts ^Mouser^Reichelt^Conrad^Other^Notes^ ^Resistors^^^^^^^^^ |1 |680R 5% |0603 |R10 | | | | |Depends on Led | |2 |10K 5% |0603 |R6, R7 | | | | | | |1 |22K 5% |0603 |R8 | | | | | | |1 |33K 5% |0603 |R7 | | | | | | ^Capacitors^^^^^^^^^ |2 |100n |0603|C5, C6 | | | | | | |2 |47u |THT|C3, C4 | | | | |6mm diam. 2.5mm lead space | ^Diode ^^^^^^^^^ |1 |SB240 |DO15 |D1 |[[https://www.mouser.fr/ProductDetail/Vishay-Semiconductors/SB240-E3-54?qs=sGAEpiMZZMtQ8nqTKtFS%2fJkHNs4hgXaDEeftRftuRh8%3d|625-SB240-E3 ]] | | | | | ^LEDs^^^^^^^^^ |1 |--|0805 or THT |LED_PWR | | | | |2x5mm rectangular THT | ^IC^^^^^^^^^ |1 |LD1086DT50TR|DPACK|IC2 |[[https://www.mouser.fr/ProductDetail/STMicroelectronics/LD1086DT50TR?qs=%2fha2pyFadui3hFJs4DE%252bMyj510Ld0X1kD8%252bba1rnRPNgIT%2fe2X3cpg%3d%3d|511-LD1086DT50TR ]] | | | | | |1 |LM321MF|SOT23-5|IC3 |[[https://www.mouser.fr/ProductDetail/Texas-Instruments/LM321MF-NOPB?qs=sGAEpiMZZMtCHixnSjNA6JlKxGj6zye%252bSqzCTYbmrdE%3d|926-LM321MF/NOPB ]] | | | |Low Power Single Op Amp | ^Switch^^^^^^^^^ |1 |E201J1AV2 |-- |PWR_SW |[[https://www.mouser.fr/ProductDetail/CK/E201J1AV2BE2?qs=sGAEpiMZZMtNT9UGfLL4eEXUF0YHaQ0QCkFF%2fw3z%2fZc%3d|611-E201-004 ]] | | | |DPDT power switch(same as Sammich...) | ^Connectors^^^^^^^^^ |1 |micro-match 2x4 |Female|J2B |[[https://www.mouser.fr/ProductDetail/TE-Connectivity/7-215079-8?qs=sGAEpiMZZMs%252bGHln7q6pm48SVpWlpfsEUiVE5fgbiD4%3d|571-7-215079-8 ]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/2178710-8?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8%2fCQlcYGYnC2hwh1bE9lC1w%3d%3d|571-2178710-8 (value line)]] | | | | | |1 |DC in Socket Opt*1 |Female|DC_IN |[[https://www.mouser.fr/ProductDetail/Phoenix-Contact/1729128?qs=%2fha2pyFadugiLMhdwEyAfMwkrEsDMI83kaSJKlExH4Y%3d| 651-1729128 ]] | | | |Jack on board | |1 |DC in Socket Opt*2 |Female|DC_IN |[[https://www.mouser.fr/ProductDetail/Phoenix-Contact/1729128?qs=%2fha2pyFadugiLMhdwEyAfMwkrEsDMI83kaSJKlExH4Y%3d| 651-1729128 ]]+ [[https://www.mouser.fr/ProductDetail/?qs=I3kMT7EEIOXXob2Ub%2fzU5g%3d%3d|502-712A ]] | | | |Screw terminal on board(Board/Switch on front) + Jack on backpanel | ^Others ^^^^^^^^^ |2 |Screw terminal |-- |-- |[[https://www.mouser.fr/ProductDetail/534-7790|534-7790 ]] | | | | | \\ ==== SD Card Module ==== version 1. Mouser BOM:<wrap round todo 7%>toDo</wrap> ^Qty ^Value ^Package ^Parts ^Mouser^Reichelt^Conrad^Other^Notes^ ^Resistors^^^^^^^^^ |2 |680R 5% |0603 |R15, R16 | | | | |Depends on Led | |2 |100K 5% |0603 |R13, R14 | | | | | | ^Capacitors^^^^^^^^^ |2 |100n |0603|C11, C12 | | | | | | ^LEDs^^^^^^^^^ |2 |--|0805 or THT |LED1, LED2 | | | | |2x5mm rectangular THT | ^Switches^^^^^^^^^ |2 |B3F-31xx |-- |USER, RESET |[[https://www.mouser.fr/ProductDetail/Omron-Electronics/B3F-3122?qs=sGAEpiMZZMsgGjVA3toVBLOYoGzF1EI%252baICPHiOMB%252bk%3d| 653-B3F-3122 ]] | | | | | ^Connectors^^^^^^^^^ |1 |DM3AT-SF-PEJM5 |Socket |micro-SD |[[https://www.mouser.fr/ProductDetail/Hirose-Connector/DM3AT-SF-PEJM5?qs=sGAEpiMZZMuJakaoiLiBpvjg2IzEXJkOoUNaxaL8lrc%3d|571-8-215079-4 ]] | | | |with push-push | |1 |2x7 |Female |J16E |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215079-4?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgiXa3C2mAfII%3d|571-8-215079-4 ]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/1-2178710-4?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz89XsOpPMY05YgpC5omewCbA%3d%3d|571-1-2178710-4 (value line)]] | | | | | ^Others ^^^^^^^^^ |2 |Screw terminal |-- |-- |[[https://www.mouser.fr/ProductDetail/534-7790|534-7790 ]] | | | | | \\ ==== MCAN Module ==== version 1. Mouser BOM:<wrap round todo 7%>toDo</wrap> ^Qty ^Value ^Package ^Parts ^Mouser^Reichelt^Conrad^Other^Notes^ ^Resistors^^^^^^^^^ |1 |100R 5% |0603 |R12 | | | | | | |1 |1K 5% |0603 |R11 | | | | | | ^PTC fuses, resettable thermistors^^^^^^^^^ |1 |1206L150THWR|1206|F2|[[https://www.mouser.fr/ProductDetail/Littelfuse/1206L150THWR?qs=%2fha2pyFaduhlexFGoLte04X2tL%252bbW3Ma%252b9epP3LU68QBDZh6rRT18Q%3d%3d|576-1206L150THWR]] | | | | | ^Capacitors^^^^^^^^^ |2 |100n |0603|C8, C10 | | | | | | |2 |1u |3225|C7, C9 | | | | | | ^ESD Suppressors / TVS Diodes ^^^^^^^^^ |1 |PESD1CAN |SOT23|Z8 |[[https://www.mouser.fr/ProductDetail/Nexperia/PESD1CAN215?qs=sGAEpiMZZMvxHShE6Whpu488MjWF3ynDhALtHXc07V8%3d|771-PESD1CAN-T/R ]] | | | | | ^Diodes ^^^^^^^^^ |1 |LSM115J |DO214BA |D2 |[[https://www.mouser.fr/ProductDetail/Microsemi/LSM115JE3-TR13?qs=%2fha2pyFaduiBo24XIfmExf5dedveWHhL3C33TtbpFSc%3d|494-LSM115JE3/TR13 ]] | | | | | ^Ferrite Bead^^^^^^^^^ |1 |BLM21|0805|L2 |[[https://www.mouser.fr/ProductDetail/Murata-Electronics/BLM21PG221SN1D?qs=sGAEpiMZZMtdyQheitOmRdaiwhWWI9YttJulw31NHCk%3d|512-1N4148WS ]] | | | | | ^Relay^^^^^^^^^ |1 |TLP175A |SOP4 |Q1 |[[https://www.mouser.fr/ProductDetail/Toshiba/TLP175ATPLE?qs=%2fha2pyFaduisaqnSTyA1UgNCMWNEP9fwGDCl8Iqoe5E%3d|757-TLP175A(TPLE ]] | | | |Photorelay MOSFET | ^IC^^^^^^^^^ |1 |TCAN1042GV|SOIC8|IC4 |[[https://www.mouser.fr/ProductDetail/Texas-Instruments/TCAN1042GVDRQ1?qs=sGAEpiMZZMsGqoCZrYwANq5ED54tVtBfM78HVPcr0sA%3d|595-TCAN1042GVDRQ1 ]] | | | |CAN tranceiver | ^Switch^^^^^^^^^ |1 |1101M2S3AV2BE2 |-- |TERM |[[https://www.mouser.fr/ProductDetail/CK/1101M2S3AV2BE2?qs=%2fha2pyFadujD6JulctD4kEoM1Xzd%252bRes6EY%2f5vM%2fBxlqclCHPs%252b67Q%3d%3d|611-1101M2S3AV2BE2 ]] | | | | | ^Connectors^^^^^^^^^ |1 |RJE0166202 |dual RJ11 6p6c |MCAN |[[https://www.mouser.fr/ProductDetail/Amphenol-Commercial-Products/RJE01-662-02?qs=sGAEpiMZZMvQhAhQbXdbBi%252bEAaZmt%2fbbP%2fIlzRHV1Ug%3d|523-RJE01-662-02 ]] | | | | | |1 |micro-match2x3 |Female |J18 |[[https://www.mouser.fr/ProductDetail/TE-Connectivity/215079-6?qs=sGAEpiMZZMs%252bGHln7q6pm48SVpWlpfsECZqIi2rkWjs%3d|571-215079-6]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/2178710-6?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8lDoKaCIVjpqtoiZwdtC2Ng%3d%3d|571-2178710-6 (value line)]] | | | | | ^Others ^^^^^^^^^ |2 |Screw terminal |-- |-- |[[https://www.mouser.fr/ProductDetail/534-7790|534-7790 ]] | | | | | \\ ----
