dipboardf4_modules
−Table of Contents
dipBoardF4 Modules
Basic connection Modules for dipBoardF4 and dipCoreF4.
Features
- Dual OTG USB, one Dual role(mini-AB, B) and second is Host only(A).
- DC Input 9-12V with 5V regulator, switch and led.
- In device Mode, VBUS is switched off when DC Input is enough to supply the 5V regulator.
- Power switch also acts on USB powering.
- micro-SD Card socket with push-push.
- Reset and User buttons, 2 leds for user purpose.
- Dual MCAN bus RJ11 connectors with 120Ω termination switch.
Dimension
PCB
BOMs
USB Module
version 1. Mouser BOM:toDo
Qty | Value | Package | Parts | Mouser | Reichelt | Conrad | Other | Notes |
Resistors | ||||||||
4 | 22R 5% | 0603 | R1, R2, R3, R4 | 667-ERJ-PA3J220V | ||||
1 | 680R 5% | 0603 | R5 | 667-ERJ-PA3J681V | Depends on Led | |||
PTC fuses, resettable thermistors | ||||||||
1 | 1206L150THWR | 1206 | F1 | 576-1206L150THWR | ||||
Capacitors | ||||||||
1 | 100n | 0603 | C2 | 80-C0603C104Z3V | ||||
1 | 4,7u Tantalum | SMC_A(1206) | C1 | 647-F931C475MAA | ||||
ESD Suppressors / TVS Diodes | ||||||||
7 | CG0603MLC-05E | 0603 | Z1, Z2, Z3, Z4, Z5, Z6, Z7 | 652-CG0603MLC-05E | ||||
Ferrite Bead | ||||||||
1 | BLM21 | 0805 | L1 | 81-BLM21P331SG | ||||
LEDs | ||||||||
1 | – | 0805 or THT | LED_OC | 755-SML-H12U8TT86C(0805) | 2x5mm rectangular THT | |||
Transistor | ||||||||
1 | FDN304P | SSOT-3 | Q1 | 512-FDN304P | P-Channel MOSFET | |||
IC | ||||||||
1 | STMPS2161STR | SOT23-5L | IC1 | 511-STMPS2161STR | Power Switch IC | |||
Connectors | ||||||||
1 | mini-USB | THT | MINI-USB | 571-1734510-1 | ||||
1 | USB-B | THT | USB-B | 538-67068-8000 | ||||
1 | USB-A | THT | USB-A | 538-48204-0001 | ||||
1 | micro-match 2×4 | Female | J2A | 571-7-215079-8 or 571-2178710-8 (value line) | ||||
1 | micro-match 2×6 | Female | J1A | 571-8-215079-2 or 571-1-2178710-2 (value line) | ||||
Others | ||||||||
2 | Screw terminal | – | – | 534-7790 |
External Power Module
1 | 680R 5% | 0603 | R10 | 667-ERJ-PA3J681V | Depends on Led | |||
2 | 10K 1% | 0603 | R6, R7 | 755-ESR03EZPF1002 | ||||
1 | 22K 1% | 0603 | R8 | 755-ESR03EZPF2202 | ||||
1 | 33K 1% | 0603 | R7 | 667-ERJ-PA3F3302V | ||||
2 | 100n | 0603 | C5, C6 | 80-C0603C104Z3V | ||||
2 | 10u | THT | C3, C4 | 667-ECE-A1HKA100I | 6mm diam. max, 2.5mm lead space | |||
Diode | ||||||||
1 | SB240 | DO15 | D1 | 625-SB240-E3 | ||||
LEDs | ||||||||
1 | – | 0805 or THT | LED_PWR | 755-SML-H12U8TT86C(0805) | 2x5mm rectangular THT | |||
IC | ||||||||
1 | LD1086DT50TR | DPACK | IC2 | 511-LD1086DT50TR | ||||
1 | LM321MF | SOT23-5 | IC3 | 926-LM321MF/NOPB | Low Power Single Op Amp | |||
Switch | ||||||||
1 | E201J1AV2 | – | PWR_SW | 611-E201-004 | DPDT power switch(same as Sammich…) | |||
1 | micro-match 2×4 | Female | J2B | 571-7-215079-8 or 571-2178710-8 (value line) | ||||
1 | DC in Socket Opt*1 | Female | DC_IN | 490-PJ-037A | Jack on board | |||
1 | DC in Socket Opt*2 | Female | DC_IN | 651-1729128 + 502-712A | Screw terminal on board(Board/Switch on front) + Jack on backpanel | |||
Others | ||||||||
SD Card Module
2 | 680R 5% | 0603 | R15, R16 | 667-ERJ-PA3J681V | Depends on Led | |||
2 | 100K 5% | 0603 | R13, R14 | 755-ESR03EZPJ104 | ||||
2 | 100n | 0603 | C11, C12 | 80-C0603C104Z3V | ||||
LEDs | ||||||||
2 | – | 0805 or THT | LED1, LED2 | 755-SML-H12U8TT86C(0805) | 2x5mm rectangular THT | |||
Switches | ||||||||
2 | B3F-31xx | – | USER, RESET | 653-B3F-3122 | ||||
1 | DM3AT-SF-PEJM5 | Socket | micro-SD | 571-8-215079-4 | with push-push | |||
1 | 2×7 | Female | J16E | 571-8-215079-4 or 571-1-2178710-4 (value line) | ||||
Others | ||||||||
MCAN Module
1 | 100R 5% | 0603 | R12 | 755-ESR03EZPF1000 | ||||
1 | 1K 5% | 0603 | R11 | 755-ESR03EZPJ102 | ||||
1 | 1206L150THWR | 1206 | F2 | 576-1206L150THWR | ||||
2 | 100n | 0603 | C8, C10 | 80-C0603C104Z3V | ||||
2 | 1u | 1210 | C7, C9 | 710-885012209003 | ||||
1 | PESD1CAN | SOT23 | Z8 | 771-PESD1CAN-T/R | ||||
Diodes | ||||||||
1 | LSM115J | DO214BA | D2 | 494-LSM115JE3/TR13 | ||||
1 | BLM21 | 0805 | L2 | 81-BLM21P331SG | ||||
Relay | ||||||||
1 | TLP175A | SOP4 | Q1 | 757-TLP175A(TPLE | Photorelay MOSFET | |||
IC | ||||||||
1 | TCAN1042GV | SOIC8 | IC4 | 595-TCAN1042GVDRQ1 | CAN tranceiver | |||
Switch | ||||||||
1 | 1101M2S3AV2BE2 | – | TERM | 611-1101M2S3AV2BE2 | ||||
1 | RJE0166202 | dual RJ11 6p6c | MCAN | 523-RJE01-662-02 | ||||
1 | micro-match2x3 | Female | J18 | 571-215079-6 or 571-2178710-6 (value line) | ||||
Others | ||||||||
dipboardf4_modules.1538989260.txt.gz · Last modified: 2018/10/08 09:01 by antichambre
