====== Display Driver - Board - for 18 SSD1306 Screens ====== {{:phatline:Display-Driver-SMD-3D-Front.jpg?600|}}\\ {{:phatline:Display-Driver-SMD-3D-Back.jpg?600|}}\\ this is one essential part for my [[triggermatrix5]]\\ I need there 18 Display, and i had good expierence with andys [[display_driver]]-board\\ since i didnt want to solder this board by hand again - i created this board. its fully SMD, and made it pick and place ready - so no soldering required!\\ ====== Shematic ====== {{:phatline:Display-Driver-SMD-Shematic.pdf?400|}}\\ {{:phatline:Display-Driver-SMD-Shematic.jpg?600|}}\\ ====== Building and BOM====== The Values are printet on the PCB.\\ {{:phatline:BLM16x16-PCB-Back.pdf?400|}}\\ {{:phatline:BLM16x16-PCB-Front.pdf?400|}}\\ ===== BOM ===== ^Comment ^Designator ^Footprint ^LCSC^ | 10uF | C1-18,C34-54 | 0805_C | CL21A106KAYNNNE | | 100n | C19-33 | 0402_C | C307331 | | - | CS1,LCD1-18,inB10,outB10,in15 | PinHead-SMD-2,54mm Pitch | C192300 | | SN74HC541 | IC1-7 | SOIC127P780X200-20N | C116811 | | 74HC595 | IC8-10 | SOIC-16 | C5947 | | 220 OHM | R1-54 | 0402_R | C25091 | | 1K OHM | R55-96 | 0402_R | C11702 | {{:phatline:Display-Driver-SMD-PCB.jpg?600|}}\\ ====== To Do ====== Order the Prototype, waiting for christmas....\\ ====== Community users working on it ====== * **[[Phatline]]** = PCB & Shematic, UI-Programming, Documentation...\\ Just let a Private message on the forum to user already involved.\\ or join the forum: [[http://midibox.org/forums/topic/24791-daw-controller-ableton/|daw-controller-ableton]]\\
