wCoreF4
Introduction
This is a cross-grade of the STM32F4 Core based on the Core407v breakout board from Waveshare. There are other versions of breakouts, but the Waveshare one seems quite a reputable source with decent distribution and documentation.
Pros
- Slightly smaller footprint
 - (Almost) all connectors on same face
 - Proper USB A and B ports
 - Footswitch/gate 3.5mm jack
 - Hardware host/slave switch
 - LEDs on the panel
 - Reset button on the panel
 - User button on header
 - More mounting options available (e.g. panel mount including USB)
 - 1A 3v3 regulator
 - Possibility for external Vref (for AIN)
Cons
- Similar height to Disco version (could cut off headers etc.)
 - Lacks ST-LINK and requires a (cheap) programmer or a Discovery module
 - No mounting holes on MCU breakout
 - Requires SMT soldering (wide pitch)
Sub parts
The Core is split over three PCBs:
Build instructions are found on the appropriate pages.
MCU module
The actual MCU module is available from several sources:
Burning the bootloader
The MCU module has a USB port, but direct programming would only be possible with a USB-UART programmer. It would also require a different bootloader protocol. Instead, we make use of ST-LINK-like functionality. The MCU module has a typical JTAG header and these pins are also available on the two 2*25 header rows. So even if the header had to be removed for space reasons, it should always be possible to re-flash the MCU.
Option 1: ST-LINK clone
These are readily available from eBay and other sellers for typically <$10. You only require one programmer to flash as many modules as needed.
Option 2: use a Discovery module
The Discovery module (even if connected to a MIDIbox Core) can be used for programming.
License
