mb-modulbox-ng
MB-ModulBox NG
Under Heavy Developpment @ 9/8/2016
Introduction
The MB-Modulbox-NG Project is a modern version of the Modulbox project .
In short words, it's a Eurorack-size compliant Modular MIDIbox Control Surface based upon MB-NG.
From a Main Part,small modules would be chained to Build the custom-sized control surface of your dreams by choosing the MIDI controls you want.
Main part would also allow Access to Menus for configuring and saving things on SD Card , and optionnal External Analog Inputs/Outputs to trigger from external sensors and/or drive your analog synth.
Each Small Module will have a Different type of Interaction and will include Digital Shift Registers and/or Multiplexers For Analog lines . Then modules would be chained one to another up to main part.
Modules Chain Connectors will be 2.54mm dual row pinheader (Molex?) and will carry Digital/Analog bus lines and Current supply. PSU Main input will be on main part PCB.
Main Part Features
  1. Standard Control Surface with 6 Tactile switches, Push - Encoder ,OLED Graphical screen
  2. SD Card Slot (+USB in?)
  3. Optionnal 16×3.5mm jacks for external Analog Ins/Analog Outs with External interfaces for expanding.
Community users working on it
  • Ksir - Modulbox Original Designer - PCB Design - Programming
  • Psykhaze - Documentation - Frontpanel design - PCB Design - Programming
  • Latigid On - PCB Design -Troubleshooting Help
Getting Involved ?
Just let a Private message on the forum to users already involved
Software Tools used
PCB process
  1. Parts List - Datasheets Gathering - Reference selection
  2. KiCAD Library
  3. Schematics
  4. FootPrint Creation / Association to schematics
  5. Netlist Export
  6. Make Pcb routing - Put pinheader/jumper to Strategic Troubleshooting Places.
Architecture
Modulbox-NG
Eurorack design
  • Eurorack Design is 3U Height So frontpanel =5,25“=133mm-rails=128,5mm Height .
    Sandwich Design is ok here due to non heating components and allow to spare space.
  • Modules Frontpanels are 8HP-multiple wide (8HP=40,3mm) see Eurorack Specification.
    Frontpanel back spacers glued with JB-weld to avoid front screwing. Eurorack Templates PDF
  • PCB Size is 100mm height To stay compliant to Eurocard Specification
Splitted View
Tech Demos Videos
Modules List + UI Parts
Module Analog LED Encoders Switches HP User Display
Main UI+Main PCB1 Jacksx16 x1 PushRotaryTactilex6 24 PsykhazeGraphic-OLEDx1
Horizontal 4xOLEDS SCSE2 x1 PushRotaryTactilex7 24 Small-OLEDx4
Vertical 4xOLEDS3 16 Small-OLEDx4
LCD Vertical SCS4 x1 PushRotaryTactilex(4+4+2)16 CLCD 20×4
LCD Horizontal SCSE5 x2 PushRotaryTactilex22 32 Psykhaze2xCLCD 40×4
Encoders x8 6 x8 PushRotary 8 Ksir
Pots x8 7 Pots x8 8 Ksir
LED Ring Encoders x48 16×4 3mm x4 PushRotary 8
Faders 2×2 9 Fadersx4 8
Light-Fader 2×210 Light-Fadersx4 8
Long Faders x2 11 Long Fadersx2 8 Psykhaze
Motor Fader x112 Motor Fader 16x3mm 8 Psykhaze
Switches x8 A13 Tactilex8 8 Ksir
Switches x8 B14 8xBicolor Toggle 3 polesx88 Ksir
Light-Switches x8 A15 Bicolor Opt Light Tactilex88 Ksir
Light-Switches x8 B16 Light Togglex88 Ksir
Numeric Displayx217 x2 PushRotary 8 2x Numeric
Numeric Displayx418 x4 PushRotary 16 4x Numeric
8×8 LED Modulation Matrix19 x(8×8)3mm Tactilex(8+8)16
16×16 LED DotMatrix20 16 Psykhaze4xDotMatrix
8×16 RGB DotMatrix21 16 Psykhaze2xDotMatrix
Additional Analog In or Out Interface22Jacksx8 x8 PushRotaryToggle 4 polesx216PsykhazeSmall-OLEDx2
Crosspoint Matrix 8×4(x4)23Jacksx(8+4)x(8×4) 3mm Toggle 4poles, Tactilex(8+4)16Psykhaze
Adafruit Silicon 3mm 8×8 Matrix24 x(8×8)3mm Adafruit Silicon (4×4)x424 Psykhaze
Joystick 25 2xJoystick 2xRGB 8
Linear Touch 26 1x(Force)Linear Sensor 8xWS2812 8 Psykhaze
Circular touch27 1x(2x)Circular Sensor16(x2)xWS2812 16 Psykhaze
Force touch 28 4xForce touch4xRGB 8
MiniDeck DJ Control291xScratchFader+ 1xVertical Faderx8 3mmx1 Code Wheel +x3 PushRotary 32
Frontpanels Layouts
. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Digital Ins 8 0>16/ 12 30 16 / 8 / / / ? 8 24 8
Digital Outs / / / / / / / 16 / / / 16+?/ 16 8>16
Analog Ins / / / / / / 16 / 8 8 4 ? / / /
CLCD # / / / 1 2 / / / / / / / / / /
OLED # 1 1>84 / / / / / / / / / / / /
. 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
Digital Ins 16 4 8 16 / / 24 15 16 16 32 / 3 / / 12
Digital Outs 8 16 32? 16 16 32 / 16 16 / / 6 / / 12 8
Analog Ins / / / / / / 0>8 / / / / 8 / 3>6 8 8
CLCD # / / / / / / / / / / / / / / / /
OLED # / / / / / / 1 / / / / / / / / /
Parts References
Parts Datasheets
Designation Datasheet Link Reference
Serial Register IN 74HC165 cd74hc165
Serial Register OUT 74HC595 cd74hc595
Line Driver 74HCT541cd74hct541
OptoCoupler 6N138 6N138M
Analog>Digital ConverterMCP3208 MCP3208
Multiplexer switch MOS4051 cd74hc4051
Digital>Analog ConverterMAX525 MAX525
Operational AmplifierMCP600X MCP6008
Crosspoint Switch CD22m3494CD22m3494
Switch Rotary Encoder Alps EC11E EC11E15244B2
5mm WS2812 LED WS2812 APA-106-F5
5mm RGB LED RGB LED SL-R596CR4G3B5W-F12
Tactile Switch Small Round Tactile SwitchSKHHDTA010
Tactile Switch 2 Square Tactile Switch 03.0752
Light-Tactile Switch Square Light Tactile switch B3W-9000-G1N, B3W-9000-R1N, B3W-9000-Y1N, B3W-9000-RG2N
Toggle Switch 3/4 PolesToggle Switch100SP1T2B3M2QEH
Light-Toggle Switch Light Toggle SwitchG12JPCF
Code Wheel+ Optical EncoderEncoder+ Code WheelHEDB-9100-C12
Fader Bourns PTAPTA3043-2015CPB103,PTA6043-2015CPB103
Long Fader ALPS RS series RSA0N11S9A0K
Long Fader 2 Bourns PTB PTB0143-2010BPB103
Light-Fader Bourns PTLPTL30-10G1-103B2, PTL30-15R1-104B2, PTL60-10G1-103B2, PTL60-15R1-104B2
Motor Fader Alps MotorFader 60mm RS60N11M9A0F
Rotary Pot ALPS Rotary potRK09L1140A66
SD Card Socket SD Socket SDCRD-GM-271
OLED 256x64px 3,12” Newhaven OLED NHD-3.12-25664UMY3
OLED 256x64px 3,2 “ 3.2" OLEDER-OLEDM032
OLED 128x64px 0,96” 0.96" OLED ER-OLEDM0.96
CLCD 20×4 20x4 LCDERM2004
CLCD 40×4 40x4 LCDERM4004
8×8 Monochrome DotMatrix 8x8 Dotmatrix TC15-11EWA
8×8 RGB DotMatrix 8x8 RGB Dotmatrix YSM-2388CRGBC
3 Digits Numeric Display 3 Digits Numeric DisplayBA56-12SRWA
Silicon 4×4 Button Matrix 5mmSilicon 4x4 5mm Button Matrix /
Silicon 4×4 Button Matrix 3mmSilicon 4x4 3mm Button Matrix /
jack 3,5mm mono Jack 3.5mm 35RAPC2AV, PJ301BM
Joystick 1 Joystick 1 /
Joystick 2 Joystick 2 /
Force Touch Sensor Interlink FSR40234-00015
Ring Sensor Interlink Ring Sensor40-24131
Linear+Force Sensor Interlink linear+force sensor34-00022
Linear Touch Sensor SpectraSymbol SoftPot SP-L-0100-103-ST
Circular Touch SensorSpectraSymbol SoftPotSP-R-0046-103-ST
Buy Places
Software / Firmware
A GUI will be developped with JUCE Library to make your MIDI mapping upon your custom control interface and make your custom infos display on OLED / CLCDs / LEDs Matrixes. Upon a list of Pre-made functions,you would be able to connect a MIDI mapping to Controller / Sequencer / Other MIDIbox apps functions into the JUCE GUI
TODO:Make a inkscape sketch For the JUCE GUI then remake it with Projucer
mb-modulbox-ng.1470802914.txt.gz · Last modified: 2016/08/10 04:21 by psykhaze
