====== SEQ V4+ ====== Around November 2016 I embarked upon a new version of the SEQ v4. Some initial concepts had an integrated 16*4 BLM included, but the idea was refined to something simpler. The goals of the project are to provide an upgraded control surface with high-quality hardware. This includes Matias keyswitches rated at 50M cycles and a streamlined workflow with a dedicated button row. Although I (latigid on) have done most of the design and prototyping, I am in communication with TK. who will cover the software changes to get the new control surface up and running. I've also had a lot of collaboration with Adrian Hallik who is looking at a case design. ===== Required modules ===== The following components are intended to comprise a full SEQ V4+: * [[SEQV4plus_le_MEC|le MEC]] (*2 required) * [[SEQV4plus_Beat_LED|Beat LED]] (optional but recommended) * [[SEQV4plus_ENC-PLATE|ENC-PLATE]] (*2 required) * [[SEQV4plus_JOG|JOG]] * Two 40*2 OLED displays (details later) * A [[wcore|wCoreF4]] including: * [[wcoref4_pcb|wCoreF4 PCB]] * [[wcore_usb|USB-power module]] * [[wcore_res-sd|RES-SD module]] * [[wcore_midi8|MIDI8]] * [[wcore_i2c|I2C]] * [[wcore_line-transmit|line-transmit]] * in effect there is space for a DB-25 expansion port, so alternative options are possible.
