Phatline
Electronic&Digital-Live-Musican
DIY-man in everything I am really interested
Europe, Austria - Katsdorf , born in 1983
take a break and listen to some music
When I want to make a track, or do a gig, i want total control of parameters, and I want to move & save them all.
There was and is a way to do that…
so back in the days i got in contact with standalone commercial sequencers like RS7000 Roland-grooveboxes or the early Electribes
Here was my first contact with Midibox…MB SID
later I did the whole thing with Ableton - , contact with Midibox Midicontrollers…
and I was very happy with the upcoming MAX4Live - it was almost perfect…, i learnt the program really well, I then just programmed a all-in-one-Groovebox in MAX without Live…
then I wanted to go to almost latency free technologies- so again i come to Midibox where i take the knowledge from the MAX-Groovebox and put it into C-codes, and that was new again, and it is still… Triggermatrix was born.
@ the moment, i am still a free artist - years of freedom, and December is always the time of year to invent new Music-Machines! I love the dark time in year… but also the summmer: where the music machines will be used… and other plans accour - of a more biological in nature livestyle, anastasia, tom brown jr, earthships, glasshouses, own grown food, electricity, water, paradiesgarten, there are more importend things… having to eat and save the environment…for me and the ones with me…
Project list
Actual Triggermatrix 5 aka TM5:
- Triggermatrix5 Overview and Build Tutorial
 - TM5-GateInput Levelshifter 5V>3V and Preamp for Gate/Trigger-Input
 - TM5-codeblock Menuesection
 - TM5-Gate-Board 3,5 Jack Boards for 16 + 16 Gates
 - TM5-DinDoutGate Module for UI and Gates for
 - Core4Disc CoreBoard for STM32F407VGT6 Discovery Boards, with some onboard Peripheral
 - Core4DiscMidiEx Midi-Expansion Board for Core4Disc
 - DisplayDriver-SMD Display Driver for 18x SSD1306 7Pin Displays
 - BLM16x16V2 16×16 Button Led Matrix
Open PAD
- OpenPAD First concept off using the MPD 226 Pads and Foil with custom PCB, with MIOS!
 - DoutX2DinX1 SMD board with free Production Files- can be used for other project too.
 - Core4OpenPAD A STM32F407VGT6 based Board - Pick and Place
paused projects:
- DAW-BTN 3+3 LED Buttons, a PCB tu build a DAW-Controller
 - DAW-Encoder-Display SSD1306 and Encoders, a PCB to build a DAW-Controller (scaleable)
 - MSQ-CC-LRE-V2 Optimized for Eurorack, now with Displays - at the moment hardcodet for Nord Drum2
 - Euro-Aout-NG-Connector-Board — a Breakoutboard for the whell known Aout-NG-Dac-Board.
 - Euro-Midi-IO — a Eurorack Sized 2IN 2THRU 2OUT Midi-IO-Board, with Midi A-B Selector…
 - LoopA-EuroRack-Panel — a Eurorack Frontpanl + Breakoutoboard for Midiphy LoopA
 - LRE-OLED-Bar — PCB to hold SSD1306 Screens above fairlightiii´smb-lre8x2cs_pcb inside Eurorack
 - SRIO-Router — 1 UI, routed to 8 Cores
 - LRE5-LCD2 — 5 Ledrings, 5 Encoders, 2 1306er LCDs, 1 Button on 10x10cm (pick and place)
 - STELLAx4 — 4x TIA Chips fired with a STM32F4, on a 10x10cm Board
 - CV1 — EuroRack - CV-Recorder - Looper, LFO, and ENV-Generator
 - CC-Looper 4CH * 128CC * 512 Step — Midi Control Change Looper
 - TriggerMatrix Specific UI
 - FILTERBOX — easy cv will move to filterbox
 - KongaTrigga — Konga > Electret Mic > Preamp > Schmitt Trigger > uC > MidiNotes
Finished
- TriggerMatrix4 TMV4
 - TriggerMatrix TMV3
 - clock2audio2clock convert Midiclock 2 Audio, record this audio, play this audio convert 2 Midiclok, for Multitrack Audio Studios without Midi, in order to overdub a track that need to be in Midi-Clock-Sync,
 - MSQ-CC-BCR some kind of a synth programmer, but with CC-Motionsequencer, and the use of BCR2000 (hardcodet for Nord Drum2, but with Mapping Array inside program)
 - MSQ-CC-LRE V1 same as MSQ-CC-BCR but, newer, faster, better… also hardcodet for Nord Drum2
Contact
triggermatrix@gmail.com
paradies@siglgut.at
My website
Forum Profile
GreatFullTekk@soundcloud
crimic@soundcloud
Youtube
Vimeo
